2003 BMW 325 car does not idle properly
JZABLOCKI18
2003 BMW 325 6 cyl Two Wheel Drive Manual 185k miles
if i leave the car off for over 4 hours it runs and turns on fine but if I stop and turn it off the start is very rough and sometimes I have lift the hood up and air it out for 10-15 mins and it will start rough again but no smoke or anything also if i turn on the headlights the idle will bounce only about 200 rpms but its not something that should happen and the tail lights only come on when the head lights are on but when i brake they dont get any darker the top brake light works fine just the left and right tail lights. should i check spark plugs and IACV?? or do you think its something more.
Aug 13, 2010 at 7:21 AM
DOCHAGERTY
  • 9,606 POSTS
Inspect the intake boot from the air mass to the throttle body. They fail all the time, cracked at the turn to the ICV.
Aug 13, 2010 at 1:01 PM
JZABLOCKI18
thanks it ended up havin a couple huge tears in it
Aug 15, 2010 at 5:08 AM
DOCHAGERTY
  • 9,606 POSTS
Thanks for donating, be here when you need us!
Aug 15, 2010 at 5:51 AM
