1985 BMW 325 SHIFTER
1985 BMW 325
KMWLY
Transmission problem
1985 BMW 325 6 cyl Wheel Drive Type unknown Manual 190,00 miles
today,upon starting to leave,i couldn't get my 1985 bmw 325e into reverse,i couldn't get any gears at first but after aprox. 7 or 8 min.'s i was able to get 3rd gear which i managed to take off in.after going several miles the gears started taking a little easier.afterparking a couple of hours,same routine.there was a slight grinding a couple of times upon changing from 2nd to 3rd also clunked a few times as was forcing to change.can you please help me with a diagnoses on this?/a few weeks ago my ex worked on my brakes could this be caused by improper pressure bleeding?
Jan 12, 2008 at 3:57 PM
DOCHAGERTY
  • 9,606 POSTS
The shift platform bushings and the shift knuckle are suspect here. the ex is not the problem.
Jan 12, 2008 at 6:08 PM
