1985 BMW 325 fuse blowing
1985 BMW 325
25,007 MILES • 6 CYL • AWD • MANUAL
SUZIE ALGER
My car is repeatedly blowing the same fuse, I thought I had found the problem and after repairing the oil pressure wire connection and cleaning up the rubber boot covering it; it seemed to be my andwer. However after I test drove it, upon returning home the fuse blew again. It lasted longer than it has been doing in the past 2 weeks. I then went back under the car to look at the oilpressure wire again and again the rubber boot covering iet was filled up with black sludge oil. Could this be the cause of the problem? If so how do I safely clean and degrease the engine underneath and under the hood without doing any more electrical damage??
Jun 10, 2008 at 6:27 AM
DOCHAGERTY
  • 9,606 POSTS
Suzie, the first item that requires replacement is the oil pressure switch. The part# is 61-31-1-354-274. Please tell us what fuse is blowing and what it does. The clean up is something I usually do with spray solvents and compressed air.
Jun 10, 2008 at 7:30 AM
