drive belt
NATE D
2000 bmw 323 ci
can anyone help me with installing the drive belt
cant find a picture showing me how the belt is run.
Oct 17, 2007 at 2:32 PM
DOCHAGERTY
  • 9,606 POSTS
starting at the at the water pump go under the deflection pulley, go over the alternator, down to the power steering pump, around the crankshaft pulley,
around the tensioner pulley, and then back to the pump. pop the cap off the tensioner pulley to access the bolt you will need to turn to install the belt.
Oct 18, 2007 at 4:18 AM
