1999 BMW 323 Manual 94000 miles
Drove only a few blocks from home in 30 degree weather, the engine was clearly not warmed up yet, however the temp guage was all the way over in the hot zone as far as it can go. Also I have noticed prior to this, that with the heat on max, the cabin never gets as hot as it should. 2 questions:
1) Should I replace the thermastat or the sending unit or both?
2) Can the car overheat, given this condition? Am I'm wondering if I can drive to a mechanic about 1/2 hour drive or get the car towed.
Thank you!
SPONSORED LINKS
Tuesday, December 4th, 2007 AT 11:14 AM
