I have a 323i year 2000 and I used a generic scanner and I came up with 109 code, what code is that?
Thank you
Aug 22, 2007 at 1:34 PM
DOCHAGERTY
✓Experienced Mechanic
is there a problem with the car? the fact that there is a fault code set does not always mean that there is a problem. generic scanners do not always tell you everything. do you have a DSC or ASC warning light on constantly? let me know asap
Sep 2, 2007 at 10:30 AM
LUBRIAUTOS
MEMBER
[quote:fdbf0687a5="Dr. Hagerty"]is there a problem with the car? the fact that there is a fault code set does not always mean that there is a problem. generic scanners do not always tell you everything. do you have a DSC or ASC warning light on constantly? let me know asap[/quote:fdbf0687a5]
No DSC or ASC light on
Sep 4, 2007 at 1:36 AM
DOCHAGERTY
Thanks for getting back promptly. If there isn't a dash warning lamp lit for the ABS system then I would not feel too concerned about it. Please keep in mind that the brake system is a safety issue and if you think there is a problem, let a BMW trained technician help you.
As I said earlier, generic scanners can sometimes give false codes or a code that is no longer pending.
