I have a 323i year 2000 and I used a generic scanner and I came up with 109 code, what code is that?
Thank you
Thank you
Aug 22, 2007 at 1:34 PM
If no ABS, DSC, or ASC warning lamp is on, do not chase code 109 from a generic scanner. Have a BMW-trained technician inspect the brakes if an actual braking problem is suspected.
The owner of a 2000 BMW 323i retrieved code 109 with a generic scanner and asked what it meant. The expert asked whether a DSC or ASC warning light was on. The owner said neither light was on. The expert advised not to be concerned without a dash warning lamp, noting that generic scanners can show false or no-longer-pending codes, and recommended a BMW-trained technician if a real brake problem is suspected.
