BMW Overheating and Coolant Loss
KAVALERIST
1989 BMW 320iA.
I had a problem with the cooling driving home from work yesterday. All of a sudden the engine began over heating and the coolant tank started spewing all the fluid out a valve in the tank cover. I shut the engine down to let it cool off. Replaced the fluid and started it up again. the same thing happened. I gave it one last shot this morning and everything was fine? Was able to drive to work. Any idea what this would be??? What parts need replacing?
greatfull for any input!
May 5, 2006 at 1:12 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like a sticky thermostat
Sep 12, 2006 at 5:49 AM
GUYGUY
Hi.
I have a 1998 528i. For some odd reasons, my water meter (or thermometer, i don't know what to accurately call it) is going out of control. Nonetheless, I noticed a pattern in its behavior: When I am driving at high speed like on the highway, there is no problem, it is right in the middle where it should be, but if i slow down or halt at a light or in traffic or park, the gauge temperature gauge slowly increases until it gets to red. I don't know what to think of it. I assumed that the fan wasn't working but when i open my hood, it is still turning. i don't know if there is a connection problem or my 02 sensor has something to do with it.
Please help me before I have to spend the big bucks trying to fix this issue.
Thank you very much.
Nov 15, 2006 at 10:59 AM
Suggested Repair
For the 1989 BMW 320i, check and replace a sticking thermostat. The later 528i question received no expert diagnosis.
Conversation Summary
The owner of a 1989 BMW 320i reported sudden overheating and coolant being forced out of the tank cap valve. Refilling and restarting repeated the problem, though the car later drove normally. An expert said it sounded like a sticky thermostat. A second owner then described a 1998 BMW 528i whose temperature gauge rises toward red at low speed or idle but stays normal on the highway, and noted the fan still turns. No expert replied to that second issue.
