1995 BMW 320 Thermostat Changing
1995 BMW 320
FITANDFRANTIC
Heater problem
1995 BMW 320 Two Wheel Drive Automatic 87347 miles
Can you let me know the process to change the thermostat please?
Aug 3, 2010 at 8:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Partially drain the coolant. Save the coolant in sealed containers if being reused or dispose of safely.
Remove the 3 bolts on the thermostat housing located at the intake side of the engine.
Pull the thermostat housing off and remove the thermostat. Note the positioning of the thermostat.
To install:
Replace the thermostat with the support bar facing out. Replace the O-ring.
Install the thermostat housing and torque the bolts to 6-7 ft. lbs. (8-10 Nm).
Fill the cooling system with coolant mixture and bleed.
Aug 3, 2010 at 10:47 PM
