1988 BMW 320 White smoke
1988 BMW 320
MEO_MATIC
Engine Cooling problem
1988 BMW 320 Two Wheel Drive Automatic
White smoke coming out from my exhaust recently. I noticed it happen after I put the antifreeze into my coolant, never happen before if I didn't put the antifreeze. The only reason for filling the antifreeze into the coolant because I just leave my car inside garage during weekdays, only used during weekend, afraid that the water will freeze up. Is there anyway I can solve this problem easily and doesn't cost lots of money? I done MOT test last October, and everything going just fine. Thank you
Dec 7, 2008 at 9:16 PM
Its probably just condensation but after awhile should clear up if not there's a problem- Are you overheating ?
Dec 7, 2008 at 9:20 PM
MEO_MATIC
thank you for your reply. no, not overheating. the white smoke keep blowing from the exhaust during driving, I can see it from my side mirror. why its only happen when i fill the coolant with antifreeze?
Dec 7, 2008 at 9:26 PM
