1992 BMW 318i No Start After Timing Chain
NOTE : BMW does not rely on timing marks for precise engine timing. Correct basic engine timing is achieved when the camshafts and crankshaft have been locked into exact alignment with special tools prior to timing chain installation.
CAUTION! : Incorrect setting/installation without the use of special tools could damage or break the camshafts. Valves could also be bent through contact with the piston crowns. Always note installation instructions and use specified special tools, procedures, and sequences.
You can try and follow these instructions on how to set the timing, but you are playing with fire if you are incorrect.
Crank over engine in direction of rotation until peaks of intake and exhaust cams in cylinder no. 1 face each other. Arrows on timing chain sprockets face up.
Installation:
Hold crankshaft in TDC position with Special Tool 11 2 300.
WARNING: Remove special tool before operating the engine.
Installation:
Align camshaft and hold it with Special Tool 11 3 240.
Camshafts can be turned on the hexagon with a 27 mm wrench.
WARNING: Don't damage the bearing plate - machine sides of open end wrench as shown if necessary.
CAUTION:
If the camshaft position has to be corrected enough that there is valve movement in cylinder no. 1 and 4, first turn the crankshaft approx. 90°away from TDC pesttion in the engine's direction of rotation and return it only after turning the camshaft. In this manner contact between valves and the piston will be avoided.
Install and unlock chain tensioner after assembling.
Press chain tensioner against the timing chain.
Recheck the camshaft adjustment.
Suggested Repair
Recheck basic engine timing with BMW special tools rather than timing marks alone. Lock the crankshaft at TDC with tool 11 2 300 and align the camshafts with tool 11 3 240 so the cylinder 1 cam peaks face each other and the sprocket arrows point up. If cam correction would move valves on cylinders 1 and 4, first turn the crank about 90 degrees from TDC in the direction of rotation to avoid valve-to-piston contact. Install and unlock the chain tensioner, press it against the chain, recheck cam adjustment, and remove the locking tools before cranking or running the engine.
Conversation Summary
The owner of a 1992 BMW 318i coupe replaced the timing chain and guide, then found the engine cranks but will not start. The expert explained that BMW timing must be set by locking the crankshaft and camshafts with special tools, not by marks alone, and outlined the alignment procedure with warnings about possible cam or valve damage if timing is incorrect.
