I'm the original owner of a 1991 BMW 318is, 183K. I have recently put it on the road after being stored for 3 years with a full tank of gas and fuel stabilizer. While highway driving it shutoff and will not start!!! Anticipating it likely being a faulty fuel pump (replaced a few years ago) which is approximately 4 years old, I tested it with a 12 volt and it humms. I have tried locating the fuel relay switch to no avail. Can you advise me of its location in the fuse box because none of the relays are labeled except on the lid of the fuse box (ie, K1-K8, if I recall)? If the relay is not the problem plz advise me of other measures to take. I attempt to crank it but the engine simply spins without cranking. I also installed high performance igniton coils 2 weeks ago to augment the chip and K&N canister, hhmmm?
Thanks in advance for your assist...
Jul 9, 2006 at 7:40 AM
