BMW 318 Exhaust Power Loss
CHARLIEBHOYISD
I have BMW 318 N Reg. That needs a new Exhaust however I don’t know if it is worth getting it fixed, as when I drive I lose power and the car stalls, is this because of the exhaust or is it separate issue/problem?
Sep 29, 2007 at 1:19 AM
MERLIN2021
  • 17,250 POSTS
It could be the catalytic converter, Try using a rubber mallett or your hand and bang on the exhaust, see if you hear anything rattling insde the exhaust, could be the convereter "bed" broke up and pieces are loged in the system, choking the engine!
Sep 29, 2007 at 1:26 AM
CHARLIEBHOYISD
[quote:f78e07ac33="merlin2021"]It could be the catalytic converter, Try using a rubber mallett or your hand and bang on the exhaust, see if you hear anything rattling insde the exhaust, could be the convereter "bed" broke up and pieces are loged in the system, choking the engine![/quote:f78e07ac33]
Hi thanks for reply.
The exhaust is in bits, could this cause the engine to lose power?
Sep 29, 2007 at 7:51 AM
Suggested Repair
Inspect the damaged exhaust and catalytic converter. Tap the converter and listen for rattling from a broken catalyst bed that can clog the system, restrict flow, and cause power loss and stalling. Repair or replace the exhaust and catalytic converter as needed.
Conversation Summary
The owner of a BMW 318 reports a failing exhaust along with power loss and stalling, and asks whether the exhaust is causing the drivability problem. An expert says a broken catalytic converter bed can rattle and lodge in the exhaust, choking the engine, and suggests tapping the exhaust to listen for internal rattling. The owner confirms the exhaust is falling apart and asks again whether that can cause power loss.
