Oil leak
BERTV49
I have a 98 318ti with approx 160 k miles. Oil continues to leak from the oil plug. I have changed the plug twice.......does the pan need to be replaced or am I missing something? And if it does is it something I can do?
Oct 30, 2007 at 9:18 AM
MERLIN2021
  • 17,250 POSTS
If the bolt will tighten, then reomve the bolt and check the plastic or neoprene washer, you should change these when you do the oil change!
Oct 30, 2007 at 9:22 AM
