1997 BMW 318 Fast Turn Signal
TC1
I have a 97 318ti and just recently when I put the turn signal on to make a right hand turn, the blinker started to blink fast indicating a burnt bulb. No problem. I leave it on and inspect the lights to find which one is out. The problem is that all the lights work. The front, rear and side lights all blink and they now blink fast as if one is burnt out. I did note that the right hand side fog light is out but other than that, all my lights work fine. It's annoying that it blinks fast. Does anyone have any ideas or is the car also indicating the fog light being out?
Jul 10, 2007 at 10:37 AM
DOCHAGERTY
  • 9,606 POSTS
recheck the bulbs and replace if any are dark or non original equipment.these cars are sensitive to this and require the 21 watt silver base original equipment bulbs
Jul 21, 2007 at 8:10 PM
Suggested Repair
Recheck all turn-signal bulbs and replace any that are dark or not original equipment. These cars require 21-watt silver-base original-equipment bulbs.
Conversation Summary
The owner of a 1997 BMW 318ti says the right turn signal blinks rapidly as if a bulb is burned out, but the front, rear, and side lights all work. The right fog light is out. The expert advises rechecking the bulbs and replacing any that are dark or not original equipment, noting these cars need 21-watt silver-base original-equipment bulbs.
