1999 BMW 318 engine light is on
87,000 MILES • 4 CYL • 2WD • MANUAL
BMW318SE
I have had the computer scanned. It tells me there is an air leak on the fuel system. Have checked from the air filter to engine cannot find fault can you help, please.
The code readout read;
code 171 check fuel supply system (EUIII code: P0170)
thank you.
tony (london, U.K)
Oct 26, 2009 at 10:51 PM
DR LOOT
  • 2,311 POSTS
[quote:3a398c8002="bmw318SE"]Computer problem
1999 BMW 318 4 cyl Two Wheel Drive Manual 87000 miles
thank you.
tony (london, U.K)[/quote:3a398c8002]
According to my OBDII manual, a code 171 indicates that the system is running lean. This is not necessarily from an air leak. It could be a faulty mass air flow meter, or could be something as simple as plugged injectors. My first step would be to put some injector cleaner in the fuel tank. My personal choice would be BG44K, although it is not carried in many parts stores. After that, I'd try to find a friend with the same car and temporarily swap MAF sensors with him to see if that cures the problem and moves it to his car. Finally, you can check for vacuum leaks by spraying starting fluid around your hoses and listening for an engine rpm change. The boot from the throttle body to the mass air flow sensor is the most likely culprit. Inspect it carefully.
Good Luck
Dr. Loot's Assistant
Oct 27, 2009 at 5:19 PM
BMW318SE
thank you for your reply.
I have changed the mass airflow meter.
Can you tell if the engine light that is on can be reset without a diagnostics computer.
thank you
Nov 3, 2009 at 2:11 AM
DOCHAGERTY
  • 9,606 POSTS
No, it cannot. It will take a scanning device to reset the light. Also check the tank vent valve. Go to Realoem.com for the exploded view of the valve and it is located on the intake manifold. Part # 11-15-7-501-567
Nov 3, 2009 at 3:23 PM
