1995 BMW 318 Suspected Head Gasket Problem
92,000 MILES • 4 CYL • 2WD • MANUAL
RICHARD BAILEY
I have a 318iS Coupe that is runing fine. Just had new Radiator fitted. Havn't used car for a while due to illness and when I checked the oil level, there was a small amount of a creamy deposit on the bottom of the dip stick.Not a lot but I am worried that it might be the Head Gasket on it's way out! I have been told that it maybe "condensation", as the vehicle has not been used for a while. Any advice would be great and would there be any other tell tale signs I could look out for.
Many thanks
Richard
Dec 20, 2007 at 1:16 AM
MERLIN2021
  • 17,250 POSTS
Open the oil fill cap, any milk in there too? Try changing the PCV, yours may not be operating properly...If it persists, have a block test done, this will determine if exhaust fumes are present in the antifreeze.
Dec 20, 2007 at 1:37 AM
