1991 BMW 318 Coolant Leak
1991 BMW 318
NJFR1106
Engine Cooling problem
1991 BMW 318 4 cyl Two Wheel Drive Manual
91 BMW 318i. I not long ago replaced my radiator, water pump, and thermostat with all of the necessary gaskets and seals. I've noticed my coolant level creeping lower and lower after a while and I can't find any puddles, white smoke, or coolant in the oil. I need to replace my valve cover gasket and fan clutch but I'm not sure if either of them would cause a leak. Would you have any ideas as to where it could be going? Any help would be greatly appreciated.
Jan 7, 2010 at 5:36 AM
2 CARVINCE
  • 31 POSTS
check inside the car on the driver side, underdash right of throttle pedal back l\side of center console .
i would say that your heater core is draining down coolant.f you see green stains on carpet.
Jan 13, 2010 at 6:50 PM
DOCHAGERTY
  • 9,606 POSTS
Have the system pressure tested, that should reveal the leak.
Jan 14, 2010 at 3:16 AM
