2000 BMW 318 water pump
2000 BMW 318
7,500 MILES • 4 CYL • 2WD • MANUAL
PSYCHO
heating thermostat water circulation not sure if water is curculating through water pump how do u check if ur water pump is working thx
Jan 1, 2008 at 6:11 AM
DOCHAGERTY
  • 9,606 POSTS
mostly you assume that the pump is working unless there is a reason not to or if the pump is leaking then you would replace it.
Jan 3, 2008 at 1:39 AM
