1985 BMW 318 I only have 2nd gear
1985 BMW 318
158,000 MILES • 4 CYL • 2WD • MANUAL
DIABLOPERO
I was driving along in the car when I suddenly lost the heater and some gauges. When I stoppod at the next light I could only use second gear. I have checked the fuses. Is it a coincidence that it happen at the same time or a wring problem
May 31, 2008 at 9:43 AM
DOCHAGERTY
  • 9,606 POSTS
sounds like the shift platform is in need of repairs. you will need to get under the car to fix this issue. it is a manual transmission, yes?
Jun 1, 2008 at 6:38 PM
DIABLOPERO
Yes it is a 5speed manual . I have read that it is an electrical problem in the newer ones.
Jun 2, 2008 at 1:53 AM
DOCHAGERTY
  • 9,606 POSTS
It is possible the shift platform has loose or broken mounts. Get under the car and inspect the shifting linkage and repost if needed.
Jun 2, 2008 at 2:48 AM
