I recently did a top-end overhaul on a Nissan YD25 engine, Tested the vehicle for 190 km. then later heard a blowing sound from the inlet valve.
I removed the cylinder head and I noticed that the one inlet valve was partially closed and was running tight, took it to the engineers to confirm. they repaired the cylinder head. After fitting it the same problem recurred after driving for 40 km.
What could be the cause?
Mar 4, 2022 at 12:50 AM
