Blower Moyer ac,heat
170,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
LAVSUCKINAIR61
  • 6 POSTS
My blower motor for,ac,heat, started making noise. Checked out filter an it was bad. So pulled it out. The blower was working for a bit. Then it started to work once in a while. Not it don't blow at all. But two times had fan on an started car, air blew out. Turned off the fan,turned back on and nothing. So can you plz tell me what to ck? Plz help can't do without this winter..
Sep 8, 2016 at 3:52 AM
SATURNTECH9
  • 30,869 POSTS
When it's not working with it turned on have you tried smacking the motor with your hand to see if it starts working?
Sep 8, 2016 at 5:31 AM
LAVSUCKINAIR61
  • 6 POSTS
No i haven't, but will ck it out in the morn. I was wondering if I could spray like WD40 in it would it help, or should i not do that?
Sep 8, 2016 at 10:50 AM
SATURNTECH9
  • 30,869 POSTS
No wd 40 that's not ment for that let me know what happens.
Sep 8, 2016 at 2:11 PM
LAVSUCKINAIR61
  • 6 POSTS
I smacked it a few times i could here it trying to come on, it sounded like something was keeping it from coming on. So next ? What if i try to blow it out with an air compressor? Where the filter goes.
Sep 9, 2016 at 12:02 PM
SATURNTECH9
  • 30,869 POSTS
If it's trying to work by smacking it sounds like you need as new blower motor.
Sep 9, 2016 at 12:36 PM
LAVSUCKINAIR61
  • 6 POSTS
Ok is there a way to test it to find out for sure?
Sep 9, 2016 at 12:39 PM
SATURNTECH9
  • 30,869 POSTS
If it wasn't working before you started smacking it then it really sounds like a bad blower motor to me.Do you have a multi meter to do some testing?
Sep 9, 2016 at 12:40 PM
LAVSUCKINAIR61
  • 6 POSTS
No i dont. And dont have anyone i can barrow from.
Sep 9, 2016 at 12:43 PM
LAVSUCKINAIR61
  • 6 POSTS
Ive looked up blower moters an theres a few, one cost like $69.00 to $170.00 so i guess i just need to take out an check to see exactly which one it is.I want to Thank you for all your help.
Sep 9, 2016 at 12:49 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome if you want to test you will need a multi meter..
Sep 9, 2016 at 12:51 PM
