Blow by
180,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
JUSTIN AQUILINA
  • 9 POSTS
I would like to know if it is normal to have an engine with blow by? It does not consume any oil.
Apr 5, 2019 at 11:53 PM
Good morning,
Blow by is normal. Your PCV system is what controls the crankcase pressure from compression passing the rings.
Excessive amounts is not right if the PCV system is clogged or the piston rings are worn out.
Apr 6, 2019 at 12:08 AM
JUSTIN AQUILINA
  • 9 POSTS
Thanks for your reply. Is it normal to have this blow by? Engine runs normally and fine without any oil consumption etc.
Apr 6, 2019 at 2:27 AM
That is not bad.
Clean out the PCV system.
Apr 6, 2019 at 2:33 AM
JUSTIN AQUILINA
  • 9 POSTS
Okay. Thanks Roy for your feedback.
Apr 6, 2019 at 2:38 AM
You're welcome.
Always glad to help.
Apr 6, 2019 at 3:21 AM
