Blinkers
170,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
CHAD DAVIS2
I have a random issue with the blinkers and brake lights.
May 23, 2017 at 10:26 AM
CARADIODOC
  • 34,415 POSTS
What is the question/symptoms/observations or clues?
May 23, 2017 at 10:32 AM
CHAD DAVIS2
The blinkers do not work properly and each day they have a new and random function.
Today whether I turn left or right on the blinker only the left lights up and now it makes the brake light blink.
May 23, 2017 at 10:35 AM
CARADIODOC
  • 34,415 POSTS
When you have some light operation but it is not correct, that is almost always due to a bad ground. To verify this, if you find, for example, the left tail light is dim, remove the right tail light bulb and you will see the left one go out completely.
As an alternative, you can measure the voltages on a rear socket. Most sockets have three wires. One will have twelve volts when the brake lights are on. A second wire will have twelve volts when the tail lights are on. The third wire is the ground. That one must never have any voltage on it. If that wire has a break in it, you will typically find around four to six volts on it when either light is turned on. If you do, follow that ground wire to find where it is broken.
The two most common causes of a bad ground are the wire is rusted off where it bolts to the body, (one wire on each side of the car), and someone installed a trailer wiring harness with Scotch-Lok connectors that do not seal out moisture. Problems develop once the exposed wire corrodes away.
May 23, 2017 at 10:49 AM
