2016 Hyundai Tucson Split Temp
88,000 MILES • 2.4L • TURBO • 4WD • AUTOMATIC
ALRAKAF23
I am trying to find where this is located. I think it must be bad because the one side blows cold air, and the other side is blowing hot air and both controllers are set at the same temperature.
Mar 1, 2023 at 10:06 PM
  • 110,251 POSTS
On this vehicle, there are two air temperature actuators. One is for the left side and the other is for the right.
I attached pics below showing the locations. Note: In pic 2, the arrow pointing at number 1 is for the left side. The number 2 part is for the right.
If you are not able to control the temperature on both sides, let me know. It would be odd for both actuators to fail at the same time.
See pics below. Note: Starting with pic 3, the replacement procedures are included for both sides.
Mar 2, 2023 at 11:51 AM
ALRAKAF23
If I install one myself, do I need to use a scan tool? Or do I just take the old one off and put the new one on?
Mar 4, 2023 at 2:55 AM
  • 110,251 POSTS
I just read through the procedure again. It indicates to install in the reverse order of removal. With that being said, it shouldn't require any programming.
joe
Mar 5, 2023 at 12:30 PM
Suggested Repair
There are separate left and right air temperature actuators. Identify the side that will not hold the set temperature and replace that actuator. Installation is the reverse of removal and does not require a scan tool or programming.
Conversation Summary
The owner of a 2016 Hyundai Tucson asked where the blend door actuator is located because one side blows cold air and the other blows hot air with both controls set the same. The expert explained that there are two air temperature actuators, one for each side, and referenced location diagrams and replacement procedures. The expert also said installation is the reverse of removal and should not require programming or a scan tool.
