2020 Ram 1500 Blend Door Actuator
89,000 MILES • 5.7L • 2WD • AUTOMATIC
SSHAFFER92
  • 22 POSTS
Where is the driver side blend door actuator located?
Nov 25, 2024 at 1:12 AM
  • 55,770 POSTS
The driver side blend door actuator is located behind the dash down low on the passenger's side. Here is the location and how to change it out. Check out the images (below). Please let us know what happens.
Nov 25, 2024 at 5:26 AM
SSHAFFER92
  • 22 POSTS
I have taken the glove boxes off, but still do not see it.
Nov 25, 2024 at 9:54 PM
  • 55,770 POSTS
It must be above or to the side of the HVAC plenum, I would use a flashlight and small mirror on a stick to find it. They only give .5 hours to change it so it can be too difficult.
Nov 26, 2024 at 3:01 AM
SSHAFFER92
  • 22 POSTS
I just had my heater core replaced and that is when the hot air stopped working. I found this connection missing a plug while looking for the actuator. Any chance you can tell me if it should be plugged into something? It is right above the heater core.
Nov 26, 2024 at 4:13 AM
SSHAFFER92
  • 22 POSTS
Is it possible the actuator is behind the radio?
Nov 26, 2024 at 4:53 AM
  • 55,770 POSTS
Yep, that will cause the issue of the heat not working. It is possible the actuator is behind the radio but can I ask if maybe the tech accidently remove the actuator and did not reinstall it? Maybe that is why we can't find it.
Nov 27, 2024 at 2:55 AM
SSHAFFER92
  • 22 POSTS
I think I found it on the bottom Of the box closer to the center. It is just tight squeeze. Is it possible for you to tell me what that other connection is for?
Nov 27, 2024 at 6:08 AM
  • 55,770 POSTS
Nice work, I can tell you what the wiring does, can you start a new thread also include an image of the connector and the wiring color.
Nov 28, 2024 at 3:36 AM
SSHAFFER92
  • 22 POSTS
I was able to replace the actuator, and everything is working properly. I just started a new post about the connector. Here is the link https://www.2carpros.com/questions/connector
Dec 2, 2024 at 10:14 PM
  • 55,770 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Dec 3, 2024 at 2:21 AM
SSHAFFER92
  • 22 POSTS
Since I replaced the blend door my ac controls will not switch off of the front vents.there is also nothing coming out of the rear vents. Any suggestions?
Dec 5, 2024 at 9:24 PM
  • 55,770 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Dec 6, 2024 at 1:52 AM
Suggested Repair
Look for the driver-side blend door actuator low on the HVAC box, toward the center, after the glove box is removed; a flashlight and inspection mirror help. If heat failed after heater-core work, confirm the actuator was reinstalled and connected, then replace it if needed. The later vent-mode issue was not diagnosed here and needs a separate diagnosis.
Conversation Summary
The owner of a 2020 Ram 1500 asked where the driver-side blend door actuator is located. The expert initially described it low behind the dash on the passenger side and suggested a light and mirror if it was not visible after glove-box removal. Heat had stopped after a heater-core replacement, and the owner also found an unplugged connector. The owner later found the actuator on the bottom of the HVAC box near the center, replaced it, and restored heat. A new problem with front and rear vent selection was deferred to a separate thread.
