battery, starter, or fly-wheel?..or something else!?
190,782 MILES • 4.7L • V8 • 2WD • AUTOMATIC
LEHUANANI
my dodge ram 1500 is not starting, it spins but dont start, like no crank, a few months ago, it started cranking slow when starting. 3 weeks ago, it finally didnt start at all, there was no spin, crank or anything when we turned the key to start it. right away we thought it was the starter so we went ahead and purchased a rebuilt starter and installed it, and but it still had the same problem as before. now my friend comes over and tells us it must be the battery, he gives us a jump and it started up. The next day, the truck didnt start again, the charge i guess did not hold overnight. anyway, my husband restarted the truck with another battery, then put back the original battery while running, the truck ran great these past couple weeks and now we back to the same starting problem. It turns, but not catching to start.
Feb 3, 2015 at 5:22 PM
CARADIODOC
  • 34,414 POSTS
First of all, never, never, ever disconnect the battery while the engine is running. I can paste a copy of what can happen, but for now, if a mechanic got caught pulling that stunt, he MIGHT get one verbal warning, but for a second offense you can be sure he would be fired. Disconnecting the battery to replace it, or for any other reason, while the engine is running, has the potential to destroy every computer on the vehicle, and your truck can have over 20 of them.
A few decades ago uneducated mechanics who didn't understand how these simple systems work, removed one battery cable to verify the charging system was working, but that is a very inaccurate test, and those cars only had light bulbs that could be burned out.
What you described sounds typical of a failing charging system. You can start the testing yourself although the results can be misleading. Use an inexpensive digital voltmeter to measure the battery voltage while the engine is running. It must be between 13.75 and 14.75 volts. If it is low, suspect the alternator, but don't replace it until we perform a few simple tests to rule out other causes.
If the voltage is within the acceptable range, a professional load tester is needed for the rest of the tests. That involves measuring how much current the alternator can deliver under maximum load for only a few seconds. It must be able to develop its rated current which is typically 90 amps or more. A common failure is one failed diode of the six. With that, the alternator will only be able to develop exactly one third of its rated current. 30 amps from the common 90 amp unit is not enough to run the entire electrical system under all conditions. The battery will have to make up the difference until it slowly runs down over days or weeks.
The load tester will also measure "ripple" voltage. If a diode has failed, ripple voltage will be very high. It's that ripple voltage that can trigger the charging voltage to go as high as 30 volts. The battery is the key component in damping and absorbing that ripple voltage and other voltage spikes, and the voltage regulator needs it to hold the charging voltage down to a safe level.
Feb 3, 2015 at 5:49 PM
LEHUANANI
first of all, THANX caradiodoc!!!..ok, so most likely its to do with the battery system... my friend is a retired mechanic and he did listen how its trying to start but no crank from engine, he believes its a bad battery or battery connection also (he does not know bout the switching batterys while engine on part, though, he probly wudve said what yu did)..and how do i know if that removing the battery and replacing another while running has not destroyed any of my trucks computer systems???..
Feb 3, 2015 at 7:16 PM
CARADIODOC
  • 34,414 POSTS
I'm really aggravated with the insane engineers who seem to have the need to hang an unnecessary computer onto every system that never needed a computer before. (My '88 Grand Caravan daily driver has one very appropriate Engine Computer, and that's it. I have all the toys, like power windows, locks, and seat, and none of them need a computer.
When a computer DOES fail, you'll see some function or system no longer working. When system voltage goes high enough to damage a computer, that one will be dead, and possibly blow a fuse or two. What usually will not happen is individual functions within that computer stops working. As an example, a Transmission Computer that's damaged this way will cause the transmission to stay in one gear. It will not cause something like shifting at the wrong speeds or skipping a gear. A Body Computer won't cause just inoperative interior lights. It will cause all the system it controls to be dead. That includes wipers, power locks, and in some cases, power windows and / or remote keyless entry.
To check the starting system, start by measuring the battery voltage, but the meter probes should be right on the battery's posts, not the cable clamps. A good, fully-charged battery will measure 12.6 volts. If you find it close to 12.4 volts, it's run down. If it's good but totally dead, it will measure closer to 12.2 volts. In that case, charge it at a slow rate for an hour, then recheck it. Once it's at 12.6 volts, it should crank the engine fast enough for it to start.
If you still have a slow-crank condition, measure the battery voltage again while a helper cranks the engine. Let me know what voltage you find during cranking. If it stays above 9.6 volts during cranking, move the voltmeter probes to those cable clamps and measure again. You should find exactly the same voltage. If it is considerably lower, one of those connections is loose or dirty.
If the voltage right on the battery posts drops below 9.6 volts during cranking, even after charging the battery, it is worn out. Normally there's no guesswork. With a bad battery, the voltage will drop real low. Also, it may measure around 11 volts or less when you're not cranking the engine if it has a shorted cell.
Feb 3, 2015 at 8:37 PM
LEHUANANI
hey, did a free battery test at a gas station, using a midtronics mdx-p300 meter and it says i have a "good battery". It read at 12.64 volts, measured at 845CCA, and rating at 725CCA.
This device also tested the starter at 11.44 volts, it pointed out starter for a "normal" reading.
And also, the charging test read out to be "ok", at 13.68 volts.
So, thats all ruled out to the problem. my friend did jump start it today, started right up, ran really good, and did some errands with no problem! Did a test start before ending the night and it started right up. We will be checking wires and terminals tomorrow, and may need help identifying proper fuses and relays to check. Any other suggestions?
Feb 4, 2015 at 8:18 PM
CARADIODOC
  • 34,414 POSTS
You might get away with 13.68 volts from the alternator, but the normal range is between 13.75 and 14.75 volts. With a fully-charged battery like yours, charging system voltage will rise a little, so I'd like to see more than what you have.
They missed one important test. That's current output from the alternator under full load. A common maximum current rating is 90 amps. As I mentioned a few days ago, if your alternator has one bad diode of the six, you will lose exactly two thirds of that capacity, and 30 amps is all you'll be able to get. That's not enough, and you'll have a battery too run down to start the engine within a few days again.
Feb 6, 2015 at 4:22 AM
