battery light comes on and then goes off while driving sometimes
190,000 MILES • V6 • AUTOMATIC
CINDYSUE
Over the last couple of years I have noticed a quick blink of the battery light coming on and just as quick turning off so fast I would be like did I imagine that? It would only happen about once every couple of months. Over the last 2 weeks it has been coming on a lot now and staying on a little bit longer as time progresses. But always turns off after about 3-5 seconds or so. I took it into a local shop who states battery and alternator is fine and say they need to check the electrical system for $100 to see if it is anything there. I have put a lot of money into this car, but is this something I am going to be able to afford to fix/worth fixing? Any ideas what this could be? I haven't driven it much since this has been progressing I am afraid to get stranded while driving.
Nov 6, 2014 at 1:51 AM
HMAC300
  • 48,601 POSTS
check battery cables where they connect for corrosion. Also belt and tensioner recommended replacement is 60k so it may be slipping on start up. Otherwise if its ok let it go for a while unless it really bugs you.
Nov 6, 2014 at 4:34 AM
