Battery light and turn signal, brake light right side and lis plat lights out
JERRYW39
MEMBER
2003 FORD F-150
5.4L
V8
4WD
AUTOMATIC
165,000 MILES
Battery light stays on until I slow down and goes out, also my right turn signal and break light and license plate lights are out.
Friday, May 29th, 2015 AT 8:53 AM
HMAC300
MECHANIC
I am assuming you have replaced bulb so check to see if it gets power if it does clean the ground and make the ground better so it will work. Check battery for condition including load test most places do for free they can also check your charging system at same time. Try replacing belt and tensioner recommended at 60k for both it may be slipping at higher rpm.
