I just put a battery charger on my van battery to give it a full charge since I mostly do more around town driving then long-distance driving. When it completed, I let it sit to let the surface charge wear off, and when I checked it with my volt meter. It is only sitting at 12.3 instead of 12.5 or 6. The charger I got recommends using it on 12 volts batteries with rated capacities 22-75 Ah. The battery in the van says its Ah is 80. Would this be causing it?
Sep 30, 2018 at 9:17 AM
