Battery
10,800 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
KBGCJR7081
I jump my son, turn off the car try to start it a couple of times it started. then came home the next day it started. went to the bank turn it off wouldn't start. play with the cables it started got it home hasn't started check the relays the starter.
Dec 22, 2018 at 11:49 PM
  • 110,248 POSTS
Based on your description, it sounds like you either have a loose connection or a corrosion issue on the battery. Do me a favor, read through this link and do what it says. I think this is the issue.
Let me know the results or if you have other questions.
Dec 23, 2018 at 10:11 AM
