2000 Subaru Legacy Installation of Battery
2000 SUBARU LEGACY
101,000 MILES • 4 CYL • FWD • AUTOMATIC
TED FEATHER
In addition to the red positive and black negative cables, there is a third cable. I suppose it is a ground? Where does it connect?
Dec 10, 2008 at 5:07 AM
MIKE H R
  • 3,094 POSTS
Well on some they have four cables. The big red one is positive, a smaller red one is power to the fuse box undert the hood.. Then you have two wire on the negative side. the big black with yellow stripe one goes to the engine block {engine ground} then you have a smaller black with a yellow stripe that goes to the body and is the body ground.
Dec 17, 2008 at 7:58 AM
