Basic...fan clutch issues, fluid leak
185,000 MILES • 4.2L • V6 • 4WD • AUTOMATIC
IMAGINE62
Hi...new here,, female "attempting" all work by myself....
I bought this TB 2 months ago, starting to regret it.. ( wanna go back to jeep!)
Any way besides basic things I did
I replaced FAN CLUTCH,,,nothing but problems since then ( codes 1484..& 1481). Just went to junk yard to get the top harness part ( the part that comes from fuse box? Thinking of splicing wires for this ( not sure if Well lose voltage)
Damn thing sounds like a JET,,,if I didn't know the difference would swear it's the tranny acting up!!!
Also have a fluid leak...I know one is the line from passenger side tranny cooling line,haven't replace that yet
But side of passenger under steering pump,,there is fluid under that,,checked the lines to n from that all dry n fluid is full in there
The fluid isn't "red" so NOT tranny or power steering....
Oh, how I wish one of you experts are in NY. That would lend a hand..lol
Any help would be greatly appreciated
Apr 18, 2016 at 9:54 AM
IMAGINE62
Oh..forgot to mention MOST issues started after stupidly disconnected neg cable to check fuses...
Also airbag light is on...don't know if that off sets anything?
Wondering if PMC is a part of issue,,???
Thanks
Apr 18, 2016 at 10:17 AM
LOU P
  • 118 POSTS
Hello, lets take each issue one at a time, first the fan clutch, why did you replace it and where did you get the new part from?
Apr 18, 2016 at 12:41 PM
IMAGINE62
Bought from am-auto parts
Had code p1484... So replaced it.
Now I have a ticking coming from it...seriously thinking of getting one from junk yard at least it will be an original from Chevy/gm...
Now have code p1481--- harness
Cut a piece off a cars in junk yard to splice together
Now there's a ticking so I know def the clutch itself...had the place I bought it from send me another one,,,just gonna have to change it...
I thank u for help
If u think of anything else feel free to share
Apr 19, 2016 at 7:06 AM
IMAGINE62
Update...
Actually changed tranny cooler line (woohoo to me)
Strange thing the fan clutch sounds better???...
Gonna give a few more days to see if SES light goes off,,,,if not going to look into
Having PMC flashed/updated...
Any one have any thoughts???
Apr 20, 2016 at 11:07 AM
LOU P
  • 118 POSTS
ok i think trying a used fan clutch is a good idea, you need to be careful as it seems you are attacking this thing head on with no reason as to why you are doing the work, i have access to the diagnostic process for all fault codes and issues so its better to attack a single issue at a time and stay on point, the more you change the more you risk of causing another issue .
Apr 20, 2016 at 12:33 PM
LOU P
  • 118 POSTS
