bad temperature sensor
193,000 MILES • 3.4L • 6 CYL • RWD • AUTOMATIC
BRIAN K CONNER
  • 35 POSTS
replaced cooling fan because it was bad and now the fan does not turn on when temperature rises.The gauge on the dash is reading a temperature but fan does not turn on. Will the temperature sensor still make the gauge on the dash but not switch the fan on when it reaches a temperature?
Jun 10, 2017 at 6:41 AM
CARADIODOC
  • 34,415 POSTS
Your engine should have two coolant temperature sensors. The single-wire sensor is for the dash gauge, and the two-wire sensor is for the engine computer. Both of those have a very low failure rate because there is just one component inside them. More problems occur from wiring and connector terminal problems.
If the old fan motor had tight bearings, that would have made it draw very high current, and typically blow a fuse. Where I would start is by locating the fan relay, removing it, then checking for twelve volts on one of the terminals in the socket. Some vehicles used a fuse link wire, and when that burns open, it leaves a carbon track behind. That can conduct enough current for a digital voltmeter to see a voltage and give a false reading. Testing for that twelve volts is best done with a test light. If a fuse link wire is burned open, the test light will not light up. That is the more accurate tool for this type of problem.
Jun 10, 2017 at 6:58 AM
BRIAN K CONNER
  • 35 POSTS
Okay, so I have twelve volts to one of the terminals for the relay but still no fan . I took a jumper wire and ran it from the terminal I tested to one of the other terminals and the fan came on so I guess that eliminates the possibility of a wire being burned?
Jun 10, 2017 at 10:07 PM
CARADIODOC
  • 34,415 POSTS
Yup. That proves the high-current circuit is working. The suspects now are a defective relay, or the Engine Computer is not turning that relay on. On most cars, if you turn on the ignition switch, then unplug the two-wire coolant temperature sensor, the fan relay will be turned on by default. The Engine Computer will see the sensor circuit has a defect, and will turn the fan on just in case there is an overheating problem.
If the fan runs when you unplug the sensor, you likely do not have a problem. A lot of GM engines have to get as high as 226 degrees before the fan turns on.
If you hear the fan relay click, but the fan doesn't run, suspect the relay. Swap it with one of the other ones like it as a test.
Jun 12, 2017 at 12:56 PM
BRIAN K CONNER
  • 35 POSTS
Nope none of the above. Temp sensor switch was the problem. All is working properly now. Thanks for your input though.
Jun 12, 2017 at 7:35 PM
CARADIODOC
  • 34,415 POSTS
Dandy. Happy to hear you solved it.
Be aware temperature sensors have a very low failure rate. As they get hotter, the resistance of its internal temperature-dependent resistor goes down. The Engine Computer reads that resistance to calculate temperature. A much more common cause of this problem is corrosion on the connector terminals. That will add to the resistance and cause the computer to interpret a lower-than-actual temperature. The total resistance may never get low enough for the computer to turn on the fan.
If the problem occurs again, try cleaning the terminals in the plug.
Jun 13, 2017 at 1:43 PM
BRIAN K CONNER
  • 35 POSTS
Will do
Jun 13, 2017 at 7:12 PM
  • 55,770 POSTS
Caradiodoc is one of our best!
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Jun 16, 2017 at 4:29 AM
BRIAN K CONNER
  • 35 POSTS
I sure will u have been a big help
Jun 16, 2017 at 5:10 AM
