Oil pressure sensor keeps going bad?
2006 CHEVROLET TAHOE
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
NICKBAMA14
  • 5 POSTS
I will replace and 2 to 3 months later it will go bad. I can deal with a bad OPS as I check my oil every fill up on gas. My question is, sometimes my oil pressure gauge drops to zero triggering the low oil pressure warning on the information center, does my make/model have an auto shut off when this happens?
Dec 14, 2019 at 8:14 AM
Good evening,
No, there is no protection for low oil pressure. You just have the warning.
When you changed the sensor, did you replace the pigtail on the connector?
I would also check the actual pressure with a manual gauge to be sure there is not an actual oil pressure issue.
Dec 14, 2019 at 8:19 AM
NICKBAMA14
  • 5 POSTS
Thanks for the prompt reply. Pigtail probably not replaced as I just had a re-manufactured 5.3 installed less than 10,000 miles ago. I have no visible leaks and sufficient oil level. It never makes any kind of noises indicating a lack of oil and it never starts to over heat. The auto shut off was my only big worry until I can correct the OPS pigtail.
Dec 14, 2019 at 8:34 AM
Got it. Replace the pigtail and I would still check the pressure to be sure.
You are welcome.
Dec 14, 2019 at 8:40 AM
NICKBAMA14
  • 5 POSTS
Will do! Thanks for the insight, Roy.
Dec 14, 2019 at 8:53 AM
You are welcome.
Dec 14, 2019 at 8:59 AM
