If you are getting black smoke from the exhaust, the engine is running too rich. (Too much fuel being injected into the engine) If that is the case, make sure the air filter and inlet tube is not plugged. Also, there is an engine coolant temperature sensor (ECT) for the computer and not the gauge in the vehicle. It provides an input to the Powertrain Control Module (PCM). The PCM uses engine coolant temperature data to adjust the fuel injection base pulse width, EGR flow, and ignition timing. If, for example, the ECT tells the PCM that the coolant temperature is -50 degrees F, the computer will run the fuel air mixture extremely rich so the engine can run in extreme temps. If the outside temperature is much warmer, the engine will run richer than it needs to be.
Here is what I suggest, check to see if there are any trouble codes stored in the system. Here is a link that shows how to check for codes on your vehicle.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
I suggested checking for codes to make sure there is not another issue. The tough thing is this. Even if the ECT sensor is sending a false temperature signal to the PCM, the PCM does not know it is wrong and will not show a code.
If you decide to replace the sensor, here are the directions.
COOLANT TEMPERATURE SENSOR
REMOVAL
NOTE: The Engine Coolant Temperature (ECT) sensor is located in the lower intake manifold near the water outlet connection.
1. Disconnect negative battery cable.
2. Partially drain cooling system.
3. Disconnect ECT sensor electrical connector.
4. Remove ECT sensor from lower intake manifold.
INSTALLATION
1. To install, reverse removal procedures.
2. Tighten the ECT sensor to 8-13 Nm (6-8 ft lb).
3. Refill cooling system.
NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the power-train control module relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the adaptive strategy.
______________________________________
Saturday, November 3rd, 2018 AT 7:27 PM
