Backfires
120,000 MILES • 2.4L • V6 • 4WD • AUTOMATIC
DEJI OJOAWO
My car listed above backfires when I switch off the ignition. it goes on for like three to six minutes. I noticed lately that it will not backfire when I turn off the ignition when it is in drive gear but backfires in park. Please what is the solution? Thanks
Oct 22, 2017 at 5:52 AM
  • 31,937 POSTS
Engine is running on, can be due to incorrect ignition timing, or a hot cylinder. it is basically acting like a diesel. lean mixture can cause internal cylinder temperatures to be very high, this condition can damage the engine. it can burn holes in a piston and i have seen a crank break due to run on. get this looked at ASAP.
Oct 22, 2017 at 5:27 PM
  • 55,694 POSTS
Here is a guide that can help you see whats going on,
https://www.2carpros.com/articles/engine-backfires-while-running
Cheers, Ken
Nov 1, 2017 at 11:59 AM
