Auxiliary belt, want to by-pass AC
136,000 MILES • 2.0L • TURBO • 4WD • MANUAL
HAPPYDAYS5270
I want to bypass air conditioner as the pulleys broken. What size belt do I need?
Reg rv55vmy.
Aug 18, 2018 at 5:32 AM
  • 110,248 POSTS
Chances are there is not going to be a functional way to route the belt. What I suggest is to get an AC bypass pulley. It takes the place of the compressor and then you can use the same belt and routing diagram.
There is an aftermarket company that manufacturers them. The company is Dorman and most all parts stores have access to their products. Please do not quote me, but I think the part number you need is 34283. Contact a parts store and ask if that is the correct one for your vehicle.
This is not an expensive part to get and it will make things a lot easier for you.
Aug 19, 2018 at 12:08 PM
