Automatic transmission
130,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
KERRYNIC29
To get the transmission fluid out of the transmission, the repair manual says to disconnect the cooler line below the radiator and start the engine in neutral. When I do that, no Pill pumps out the line. What would cause that besides a clogged line or just being out of oil?
Jan 27, 2016 at 2:57 AM
JOHNNYT73
  • 924 POSTS
Why not just drop the transmission pan? that way you can change the filter as well.
Jan 27, 2016 at 3:11 AM
KERRYNIC29
I did that as well, it has no filter. I just got the car, and the guy I got it from said the tyranny was bad. The first thing I did was check the fluid. It was very dark and smelled burnt. I was hoping that was the problem. But if the oil doesn't pump through to the cooler I can see why it's burnt. I want to find out if there is a pump in the tranny, or something else to keep it from pumping
Jan 27, 2016 at 3:30 AM
HMAC300
  • 48,601 POSTS
with what you described dark and burnt have a trans guy rebuild oit or put another one in from a junkyard, it's shot
Jan 27, 2016 at 4:00 AM
