2002 Audi A6 ESP Light indicator
2002 AUDI A6
80,000 MILES • 6 CYL • AWD • AUTOMATIC
JOSH0311
Yesterday my wife's Audi's ESP indicator light came on and stayed lit. The manual said to shut the car on and off, and also try pressing the ESP button. It then said that if the light remained on after that, that it is indicating a malfunction with the ESP or ABS system. My question is what is the problem diagnosis? Is this common, and is it a easy fix or a serious problem? Thank you
Sep 1, 2008 at 2:02 PM
KHLOW2008
  • 41,814 POSTS
Hi Josh0311,
There are many components and one of it is malfunctioning which can be a simple fix or expensive one. You need a scan tool to find out what is causing the error.
Sep 6, 2008 at 9:28 AM
