1999 Audi A6 Air Bag Lite stays on
141,000 MILES • 6 CYL • AWD • AUTOMATIC
DIESEL55
This car has been damaged on passenger side of car.
Because of the damage, it had a water leak with water coming in somewhere around the fire wall on the front passenger side of car.
I attempting to find and repair this water leak, a body shop, pretty much stripped down the inside front passenger and drivers side.
After getting everything back together, they could not get the "Air Bag Warning Lite" go go off once the car ignition switch was turned on.
How do I get this lite to go off?
Aug 19, 2008 at 12:29 PM
  • 31,937 POSTS
Hi there,
You will need to find a mechanic with a suitable scanner that can do a code clearing sequence, make a few phone calls and you should find one.
Mark, (mhpautos)
Aug 19, 2008 at 6:26 PM
