I bought the car with 60k. It has always leaked oil but no one knows exactly were. What to do?
Oct 31, 2007 at 4:25 AM
Inspect the oil sending unit and its protective wire tube for oil traveling into the connector and out the other end of the wire; replace the sender if it is leaking. If not, degrease the engine, idle it, and watch for the leak source.
The owner of a 1995 Audi A6 bought with 60,000 miles reports a long-standing oil leak whose source has not been identified. The expert advises checking the oil sending unit and its wiring for oil being pumped through the connector, and replacing the sender if that is the cause. Otherwise, degrease the engine and idle it so the leak is easier to spot.
