1999 Audi A4 High Fuel Use
LLOVELL
I have a 99 Audi A4 Quattro, and latley for some reason the car will go through a tank of gas in 3 days, with no long trips or excessive driving. It used to go atleast a week and a half to two weeks on one tank of gas with relativley the same amount of driving. What is wrong with my car?
Jul 12, 2006 at 2:42 AM
MOVIEPROPS
  • 6 POSTS
Check for gas leaks
Aug 8, 2006 at 8:54 AM
SYNCRAIT
  • 235 POSTS
is this an auto tranny or manual? when was the last time you did some regular maintenence on it? good luck :)
Aug 8, 2006 at 9:08 AM
2CARPRO JACK
  • 11,533 POSTS
If it has one, it sounds like the fuel press regulator might be leaking fuel into the engine
Nov 30, 2006 at 9:34 AM
GERMAN GIRL
have you figured out your problem??? i have a 2001 a6 quattro wagon and have the same problem!!!
I have a 99 Audi A4 Quattro, and latley for some reason the car will go through a tank of gas in 3 days, with no long trips or excessive driving. It used to go atleast a week and a half to two weeks on one tank of gas with relativley the same amount of driving. What is wrong with my car?[/quote]
May 10, 2007 at 2:53 AM
Suggested Repair
Check for external fuel leaks and inspect the fuel pressure regulator, which may be leaking fuel into the engine. Also confirm transmission type and recent maintenance.
Conversation Summary
The owner of a 1999 Audi A4 Quattro reports fuel use jumped from about one and a half to two weeks per tank to three days with similar driving. Replies suggest checking for gas leaks and a fuel pressure regulator leaking fuel into the engine, and ask about transmission type and recent maintenance. Another owner reports a similar issue on a 2001 A6.
