1999 Audi A4 Possible Fuel Pump Problem?
GMVIERNA
Engine Performance problem
1999 Audi A4 4 cyl Four Wheel Drive Manual
Everytime I fill my car with gas, any type of gas I have tried from high grade to regular, the car will not start. I have to keep trying and trying, and it will eventually turn on.
I have taken it to a specialized Audi Mechanic because the check engine light came on shortly after, but they have not been able to solve the problem.
It all started when I ran the car on almost empty. I told my mechanic, but he tried many things and could not eliminate the problem.
Any ideas?
Feb 5, 2009 at 1:10 PM
DOCFIXIT
  • 18,828 POSTS
Please post code in P0xx format will advise
Feb 7, 2009 at 2:48 AM
JBAIL3P
I have the same problem. Did you find a solution. Most i have read come with code P04111
Feb 20, 2009 at 3:29 AM
DOCFIXIT
  • 18,828 POSTS
Nope never heard back but your code has to do with secondary air injection pump flow to low.
When you have a no start pull plug wire see if it has spark.
Feb 21, 2009 at 2:27 AM
