2004 Audi A4 Black Smoke on Acceleration
OMAIR
hi. i have a 2004 uk Audi A4 1.9tdi (130), manual. it has only done 27000 miles but im getting alot of thick black smoke from the exhaust eveytime i accelerate. there is no loss in power and the fuel economy is good. the car drives smooth. i have changed the oil, fuel filter and air filter and have checked the MAF too. everthing seems fine. what can the problem be? could it be the catalytic converter?
Sep 8, 2007 at 11:19 AM
MERLIN2021
  • 17,250 POSTS
The car is running too rich..it is common for a fuel injector to stick open or for the fuel pressure regulator to go out and cause too much fuel pressure, this guide ca help you test it to see if this is the problem.
Please go over this guide and get back to us.
Sep 9, 2007 at 2:27 AM
Suggested Repair
Test fuel system pressure and the fuel pressure regulator. A stuck-open fuel injector or a failed regulator can cause a rich mixture and black smoke.
Conversation Summary
The owner of a 2004 Audi A4 1.9 TDI reports thick black smoke on acceleration with no power loss and good fuel economy after changing the oil, fuel filter, and air filter and checking the MAF. The expert says the engine is running too rich and recommends testing fuel pressure and the regulator, noting a stuck-open injector or failed regulator can deliver too much fuel.
