2000 Audi A4 Just bought a used Audi A4 and has a few probl
MCHLHOLBROOK
  • 2000 AUDI A4
  • 4 CYL
  • AWD
  • 126,000 MILES
I just bought the car so I don't know the correct category and if the problems are related or not. But the 1st problem is that a check engine light is on but it will not connect to the code reader at a couple places and the fuse is okay. Second is the engine stutters when accelerating especially under hard acceleration at around 40 and 80 mph typically around 5500 RPM. Third the transmission after being driven around a bit will get rough shifting from P to D and when I put it in Reverse and hit the gas pedal the car shakes violently.
Sunday, February 21st, 2010 AT 2:04 AM
2CARPRO JACK
  • 11,533 POSTS
If fuses are good and it wont communicate with the scanner, you may have a bad computer or wiring in between.I would suggest finding a shop that is familair with Audis for this one. The other issues could be related to the computer being in a"limp" mode due to faults (engine light).
Tuesday, February 23rd, 2010 AT 8:05 AM
