1999 Audi A4 Check Engine light
JDMILLER01
1999 Audi A4 6 cyl All Wheel Drive Automatic
My son's Audi recently had the engine replaced with a used 2.8 (same as it had before) 66,000 miles (same as it had before). After having it for one day the check engine light came on and we took it back and they said the it read " something about the catalyst bank 1".....
Well, we had that replaced and have had it for a day and the check engine light came on again. So we are going to take it back tomorrow. If it reads catalyst Bank 1 or Bank 2 being bad. Does that mean that something could be coming from the engine to damage the Catalyst? We already have $3,600 in the motor and $265 for the universal catalyst.
Thanks for your help.
Sep 11, 2009 at 12:22 PM
  • 31,937 POSTS
Hi there,
Before spending any more money can you post the actual code No. as with this i can get a better idea as to what is going on.
mark (mhpautos)
Sep 11, 2009 at 1:42 PM
JDMILLER01
I had the code read this morning and here is the code number that came up. P0422..... what does that mean? and is it ok to drive until we figure it out?....I greatly appreciate your help. This car is awesome, but it's draining me BIG time!.....thanks again
Sep 12, 2009 at 6:12 AM
  • 31,937 POSTS
Hi there,
The main 2 reasons for this code being set is often a faulty 02 sensor or a vacuum leak in the induction, upsetting the actual mixture settings and throwing the 02 reading out causing this code, it can all get a bit complected but i would start with checking for a vacuum leak with a fine tooth comb, it wont take much to up set the readings also check for any exhaust leaks up stream of the 02 sensor, start here.
mark (mhpautos)
Sep 12, 2009 at 12:30 PM
