1999 Audi A4 front end vibration
BKADERA
1999 Audi A4 All Wheel Drive Automatic 160000 miles
There is a slight vibration and low pitched sound that seems to coincide with the rotation of the front right wheel. It is not noticeable at high speed, but mostly when the car is warmed up, slowing down and turning left. Following our mechanics suggestions, we have replaced the rotors and pads, and also the front right wheel bearing. The noise and vibration are still there. He says it could be coming from the drive train, but now we are not sure what to do. Help
Aug 3, 2010 at 3:37 AM
DOCFIXIT
  • 18,828 POSTS
Hi Maybe from outboard CV joint have they been checked? If you can rotate axle shaft back and forth any amount then joint is suspect.
Let me know
Thanks for donate
Aug 3, 2010 at 6:51 AM
BAMADON7925
Hey,
I'm having the same problem with my 99 a4. Did you figure it out yet? THANKS
Jan 13, 2011 at 8:00 AM
