1997 Audi A4 1997 Audi A4 will not start
ACES2027
  • 1997 AUDI A4
1997 Audi A4 4 cyl All Wheel Drive Automatic
My audi a4 will not start. It cranks but will not start. I even charged my battery on a charger and tried to jump it and still won't start. All my dashboard lights come on my gages work. After I kept trying to start it my battery died after about 2-3 minutes. Is it my battery?
Saturday, March 14th, 2009 AT 1:58 AM
Get the battery load tested if okay and the engine cranking over and refuses to start do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, March 14th, 2009 AT 2:19 AM
