Air conditioner blowing hot
2008 TOYOTA CAMRY
132,000 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
DWIGHT KIRBY
AC was blowing hot air. Express oil replaced valves and recharged. Told my wife that it might take a couple of days to start blowing cold again. Does that sound right? We have driven around stop and go plus highway since yesterday. Tepid air at best. Please advise.
Feb 24, 2018 at 12:28 AM
Good morning.
No, If they repaired it properly, it should have blown cold air immediately. Take it back and either have them fix it correctly or get a refund and take it somewhere else that can fix it.
If you have a set of gauges, give me the pressures and I can help find the issue for you. you can rent a set at a parts store.
Feb 24, 2018 at 12:54 AM
DWIGHT KIRBY
Roy,
The compressor clutch cuts in or out when ac is on and fan control is switched on or off.
Feb 25, 2018 at 5:35 AM
Okay, I understand.
Can you get a set of gauges?
Feb 25, 2018 at 7:07 AM
DWIGHT KIRBY
Roy,
Good news! We took the continuing problem back to Express Oil, had a talk with the manager, told him what you said about the timeframe of AC repair results, and got the problem resolved at no charge. The system was over-charged. Thank you for your helpful advice!
Dwight
Feb 26, 2018 at 9:17 PM
Your welcome
Feb 26, 2018 at 9:20 PM
